Results 1 to 19 of 19
Thread: Metering device?
Threaded View
14-07-2004, 12:50 PM #12
Re: Metering device?
Check also if Viton and/or Teflon, the materials of the seals can be used with R410a.
1000 US$ is too much for such a pump Apoc. For that price, we install much bigger industrial NH3 pumps.
Have you searched Ebay, for example for a hydraulic pump... can whitstand high pressures, seals easily replacable, relative cheap, ... Or a pump out of the hydraulic steering of a car.
Perhaps stupid ideas but who knows???
Instead of a LSF, you can do it optically or with very small heating probes.
It perhaps even can work the way you draw it, without a liquid receiver. You must be sure that there is allways liquid in the LP separator (to avoid cavitation in the pump)
Is a capillary tube considered to be a modulating mtering device, as a TXV is.
By TopMechanic in forum FundamentalsReplies: 10Last Post: 20-07-2006, 10:00 PM -
Switching device
By Pravin in forum ElectricalReplies: 9Last Post: 08-06-2006, 05:07 PM -
Protection device
By petre11 in forum ElectricalReplies: 11Last Post: 06-06-2006, 11:23 PM -
Energy Managment XDX Device
By Steve Wright in forum Supermarket RefrigerationReplies: 1Last Post: 08-09-2005, 06:19 PM -
metering device sizing
By dantoubiana in forum Technical SpeculationsReplies: 7Last Post: 21-01-2003, 07:17 PM
