Results 1 to 2 of 2
01-06-2009, 07:12 PM #1
Lead wall isolation for split system
We intend to install a split - type air conditioner in the x - ray room of a hospital. The walls are insolated with a lead plaque to inhibit radiation leak.
Need some info about regulations concerning perforation of the wall for the brass connection tubes between the 2 parts of the equipment. Is a 3" hole safe regarding radiation loss when the x - ray machine operates?
01-06-2009, 09:04 PM #2
Re: Lead wall isolation for split system
use a ducted system, have the ducting installed while the room is going in, should make no more of an impact than the electrical supplies or similar to the room.
i found some info on this site and google in regards to this.
al
Daikin fault codes
By Chris2005 in forum Air ConditioningReplies: 45Last Post: 21-03-2012, 10:09 PM -
What is System balance?
By shogun7 in forum Technical SpeculationsReplies: 56Last Post: 19-01-2006, 09:47 AM -
Split type wall mounting Air Conditioning system
By stevews in forum Air ConditioningReplies: 23Last Post: 11-07-2005, 09:55 AM -
Refrigeration system proposal; comments please.
By DaBit in forum Technical SpeculationsReplies: 13Last Post: 01-01-2003, 03:42 PM -
Automotive A/C Vent Temp Range vs System
By Don Browney in forum Air ConditioningReplies: 1Last Post: 15-05-2002, 06:19 AM
