Results 1 to 2 of 2
Thread: bristol a-H24B22QABCA 230vac 1ph
18-05-2009, 04:41 PM #1
I'm replacing a 3ph 480vac compressor with a 1ph 230vac compressor does anyone have wiring diagram for a bristol A-H24B22QABCA Do I need start or run capacitors? Any advice is apreciated Kfox@miindustries.com
18-05-2009, 07:30 PM #2
Re: bristol a-H24B22QABCA 230vac 1ph
Using the power of Google I started at the Bristol Compressor website.
http://www.bristolcompressors.com/
I then entered H24B22QABCA into their search box and got the specification for that compressor.
It gives details of the starting equipment needed.
However, if you download this one..
http://www.bristolcompressors.com/InfoDocs/200022.pdf
You will find the wiring diagrams as well.
Job done.Last edited by Brian_UK; 18-05-2009 at 07:33 PM.
Bristol Compressors
By Chris2005 in forum CommercialReplies: 5Last Post: 09-10-2009, 06:42 AM -
Bristol Compressor Corp
By shogun7 in forum New TechnologiesReplies: 3Last Post: 12-03-2004, 09:35 PM
