Thread: monobloc info
10-05-2009, 08:22 AM #1
monobloc info
Does anybody have or know where i can get wiring diagrams and controller settings for the following monobloc (through the wall freezer unit).
Name on casing :-Superstream
Name on controller :- Russell, Elliwel on reverse
Model on name plate:-PTL016ZR01
Thanks in advance
CB
10-05-2009, 10:26 AM #2
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: monobloc info
That is Rivacold trade names.
Check what Elliwel model# is controller.
Wiring diagram is then probably some copy or derivation of original Elliwel diagram.Last edited by nike123; 10-05-2009 at 10:29 AM.
10-05-2009, 08:13 PM #3
Re: monobloc info
Thanks Nike
I've just found out that Russell is now Rivacold, going to call them tomorrow.
CB
looking for geo thermol heat pump info
By cptrdbrd in forum Technical DiscussionsReplies: 7Last Post: 16-05-2009, 04:47 PM -
Daikin info required
By airconadam in forum Air ConditioningReplies: 5Last Post: 05-01-2009, 09:26 PM -
York ycaj Danfoss EKS65 phtq info
By tomireland in forum Trouble ShootingReplies: 13Last Post: 22-12-2008, 06:47 PM -
Need Info on C-R170H5B compressor
By Raadster in forum Air ConditioningReplies: 3Last Post: 08-07-2008, 03:56 AM -
Need info on the shaft seal system for scotsman
By The MG Pony in forum CommercialReplies: 4Last Post: 17-03-2008, 02:02 AM
