07-05-2009, 07:42 AM #1
pressuer drop across heating coil
can any one tell that how to calculate pressure drop across a coil where no coil data is available.only u have stud valves and measuring port available at inlet and outlet please.
08-05-2009, 07:22 AM #2
regarding heating coil pressure drop
can any one tell me how to calculate coil pressure drop if we have flow through the coil .23 L/s,temp inlet for water (80 deg c),inlet air temp (21 deg c),heating coil capacity 16.7 KW, available.
08-05-2009, 08:13 AM #3
Re: pressuer drop across heating coil
Your question is a little complex!
Which fluid is being used across this coil?
What is the temprature of the coil?
08-05-2009, 10:09 AM #4
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
08-05-2009, 08:38 PM #5
I have merged these posts, that's why you can see the same question asked twice.
Please do not post the same question in more than 1 thread..........you will not get an answer any quicker!
LG heat pump problem
By back2space in forum Heat PumpsReplies: 132Last Post: 01-02-2009, 11:23 PM -
A question about the pressure drop in coil .
By jackcn in forum FundamentalsReplies: 20Last Post: 13-12-2008, 05:10 PM -
heating coil or cooling coil?
By botching in forum Air ConditioningReplies: 8Last Post: 09-06-2008, 08:37 PM -
Coil Pressure Drop
By jwasir in forum FundamentalsReplies: 2Last Post: 15-04-2008, 08:41 PM -
removing humidity
By Sledge in forum Air ConditioningReplies: 31Last Post: 22-06-2007, 05:40 AM
