Results 1 to 2 of 2
Thread: Swamp Coolers!!!
29-04-2009, 08:05 PM #1
Swamp Coolers!!!
Well to be more precise - adiabatic or evaporative coolers.
Currently looking at warehose that needs some sort of cost effective ventilation. Trouble is extract vent on its own is not going to cut the mustard. Lots of internal heat gain and even with very high air change rates (60+) the summer temps would stuggle to get any lower than 30-35c.
So they need some sort of cooling. If I add an evap cooler I can reduce the air change rate to around 15 and maintain approx 25c in summer - I think.
Have any of you UK guys had any experience (good or bad) with Breezair or EcoCool models in a factory / warehouse application?
If in doubt read the instructions. If still in doubt follow them.
29-04-2009, 09:01 PM #2
Re: Swamp Coolers!!!
Breezair units were fitted to waterford glass to spot cool the glass blowers, worked well by all accounts. i suppose it depends on humidity levels as to how comfortable they can be?
al
elecstar bottle coolers
By dunny123 in forum CommercialReplies: 0Last Post: 23-12-2008, 10:23 PM -
thermoelectric air coolers?? Is it suitable??
By johnnysoprano in forum FundamentalsReplies: 3Last Post: 06-08-2005, 10:48 PM -
(Remote) Back bar coolers
By Chris2005 in forum CommercialReplies: 3Last Post: 20-03-2005, 08:31 AM -
Spot Coolers Frezer
By aaron crimmins in forum Technical SpeculationsReplies: 0Last Post: 04-09-2002, 01:36 AM
