    Apr 2009
    Macedonia
    5
    samsung sh12va1 help
    in heathing mode after fey minutes starting to flash timer and power laps (middle lamp on 5 way) and door is closing. Please help
    Apr 2009
    Macedonia
    5
    Re: samsung sh12va1 help
    Nobody can help?
    Apr 2006
    stafford
    42
    974
    can you double check the model reference please,i maybe able to
    Paul
    "KEEP IT COOL"
    Apr 2009
    Macedonia
    5
    i check model again is: Samsung power inverter SH12VA1 3.5/3.8kw
    Apr 2006
    stafford
    42
    974
    OK the power inverter of that size has not hit the UK yet (to the best of my knowledge) looking at similar models its looking like a indoor pipe thermistor fault or fan motor (give it a spin to check this)
    either way looks like you will require a visit from your local service agent
    Paul
    "KEEP IT COOL"
    Apr 2009
    Macedonia
    5
    Can someone provide me service manual for this model
    Apr 2009
    Macedonia
    5
    I open outdoor unit and on the electronic plate are 3 led diodes red green and yellow. When i run the A/C red one is blinking green is flashing and compreson is trying to run several time and at the end red end green is turned off and everything stops. Maybe this will help to find solution. Thanks
