    Mar 2007
    uk
    120
    Robertshaw Controls
    Hi All
    wondering if any can help.
    I need the cut out and cut in resistances for a Robert Shaw MP50-9203 Gaurd-Pak V motor protection system.
    Its fitted on a compressor for York LCHM60, at the minute its locked out and I am averaging 1.4 ohms across all three sensors.
    If this is within its running parameters then i know its knacked, if it isnt isnt then i will need to look into this further.
    Somerset
    69
    4,698
    Re: Robertshaw Controls
    Has the Red L.E.D. on the opto isolation board gone out?
    This lights to say motor protection is good.
    No light means an issue.
    Although I suspect you already know this from what you have said?
    495
    21
    hi coolments york motor protection on these compressors ntc as the motor gets hot then the ohms readings come down,the readings start at around 1.7k and come down to about 300 ohms and then the module cuts out so your readings are fine and your module is knackered,any other compressor problems let me know and i might be able to help
    Mar 2007
    uk
    120
    thanks grizzly, didnt know that about the light, i just know i had an open circuit across T1 & T2. that tips logged in the memory now.
    Mar 2007
    uk
    120
    Quote Originally Posted by GHAZ View Post
    Thanks for that info, i will get one on order and get back there to fit it.
  1. Johnson Controls.
    By Jacek in forum Chit Chat & Service Stories
    Last Post: 03-03-2010, 10:02 AM
  2. Controls
    By shogun7 in forum Technical Discussions
    Last Post: 28-01-2010, 01:26 AM
  3. defrost controls
    By chilldis in forum Electrical
    Last Post: 20-04-2009, 12:48 AM
  4. Honeywell Residential Controls
    By bethlehemtech in forum Tools and Calculators
    Last Post: 12-07-2008, 12:24 AM
  5. Electronic Controls
    By Bones in forum Supermarket Refrigeration
    Last Post: 04-04-2004, 06:52 AM
