    Dec 2008
    Brazil
    106
    Negative pressure
    Hi fellows
    This is an automotive a/c system:
    After charging, a student of mine is reporting negative pressure on low side port (about -27 hg) and about 100 psi high side port. I have literature about diagnostic by pressure but no one of them reports negative pressure cases. What can it be ?
    Moises
    Split Croatia
    57
    6,151
    36
    Re: Negative pressure
    Blocked expansion device, blocked filter-dryer, etc...
    Apr 2009
    Dubai, UAE
    42
    negative indicates vacuum
    Oct 2004
    Scotland
    1,454
    21
    No gas in system, also the pressure switch has either failed or doesn't exist.
    Chillin
    and go get a cuppa
    Apr 2007
    36
    371
    23
    a student of yours?!
    Dec 2008
    Australia
    48
    I agree with nike123, blockage in L/L or TX.
    Apr 2001
    79
    5,071
    35
    I agree with chillin. An automotive system has a low pressure switch which disengages the magnetic clutch on the compressor if/when the pressure is low. It is not possible for the system to run in a vacuum if this circuit is functioning properly.
  1. Capillary Tube Characteristics
    By Chef in forum Fundamentals
    Last Post: 10-03-2009, 01:03 PM
  2. Compressor loading, cooling, and range of operation.
  3. Benji
  4. Building a wine cabinet
