Thread: R22 instaed of R414A
Threaded View
02-04-2009, 11:09 AM #1
Here a question for you experts. I have a old vending machine that had the compressor replaced and filled with r414a.. well after a few years it appears to have leaked out and now i'm considering refilling it with r22. I understand i will have to replace the compressor oil with mineral oil( how much oil should i use??) and make sure o-rings are non-HNBR O-rings. So here's the question...by using r22 does this mean that I won't have the cooling capacity as with r12 or r414a??? should i just stick with r414a or make the switch back(I have lots of r22 and no r414a)
R414a or 409A
By uriredlich in forum Technical DiscussionsReplies: 3Last Post: 07-09-2008, 02:39 PM -
what is the best blend for low temp
By tony_rich in forum RefrigerantsReplies: 87Last Post: 05-08-2006, 08:29 AM
