Results 1 to 8 of 8
Thread: Compressor Windings Resistance
01-04-2009, 05:15 PM #1
Help needed please. Could anyone tell me what the resistance of the start and run windings should be on a Turk Elektrik MTH 115MT compressor please. Got this one cutting out after a few seconds on start up and would like to know what part to condemn, incidentally this one has a capacitor and PTC resistor for the start up circuit. Many thanks in advance.
01-04-2009, 05:24 PM #2
Re: Compressor Windings Resistance
Look in here, hope it will help you.
Use Embraco next time......
http://www.tee.com.tr/p_copm_r600_pd.php
01-04-2009, 07:01 PM #3
Thanks for the link Chemi-Cool but can't find any actual resistance values for the start and run windings on there, just voltage and overall wattage. The one I have here is measuring 14 ohms on both the start and the run windings, any one know if this is normal? I thought it should be slightly higher and not the same one both windings.
02-04-2009, 12:13 AM #4
Hi wood, have a look at this
http://www.google.co.nz/search?q=ref...ient=firefox-a
NormMy wife used to say you never listen to a word I say at least I think that what she said
02-04-2009, 07:38 AM #5
Brilliant! Many Thanks for your efforts Toosh, amazing what you get searching the Internet when you know what to put in search criteria. I will let you all know what the fault was when I find it!
02-04-2009, 10:47 AM #6
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
02-04-2009, 09:20 PM #7
Hi woodland you can get the same readings on some windings because they use same amount of wire on both the run and start
26-04-2009, 07:30 PM #8
It is highly unlikely that the start and run windings would have the same resistance. The start winding would usually be the lower resistance so as to draw a higher current to facilitate the torque required to start the rotor going in the required direction. in conjuntion with a capacitor. The run winding would then keep the rotor turning at a lower run current.
3 phase resistance calculation
By bill1983 in forum ElectricalReplies: 33Last Post: 05-10-2010, 08:23 PM -
PTC & NTC Probes.
By Testech in forum ElectricalReplies: 17Last Post: 06-06-2008, 10:01 PM -
Semihermetic compressor winding resistance measurement
By racktech2008 in forum Supermarket RefrigerationReplies: 18Last Post: 09-03-2008, 11:43 AM -
Fire - run capacitor, high resistance connection?
By Kenedt in forum Technical DiscussionsReplies: 13Last Post: 13-08-2007, 07:07 PM -
"calrod" resistance heaters
By kengineering in forum ElectricalReplies: 3Last Post: 06-06-2006, 12:35 AM
