Thread: custom design project
01-04-2009, 11:03 AM #1
Hi, I am a design student, who is looking for help to make a cold plate. I want to make a steel plate 100cm/50cm with copper pipe running the underside, then connect this up to a domestic freezer system (from an old freezer). This should make a working cold plate, should it not? I want it to be cold enough to form condensation from the air.
Any info on who could help me or where i can already get such a thing, would be appreciated. I have a very limited student budget, so any favors i can grab , would be seen as a great help.
thanks
jamie
02-04-2009, 01:39 AM #2
Re: custom design project
please only post the message in one location. Multiple posts will not generate responses any faster and it eats up space on the server.
Thanks.If all else fails, ask for help.
16-04-2009, 05:16 PM #3
Hi Jamie :
Could you explain more specific details about your student project.
- Are you planning or calculating load of system based on desired working conditions , type of refrigerant, local temperatures, etc. What conditions and knowledge do you have about.
- Or is only a technical application work using refrigeration equipment?
What design factors decides power comsumption
By kln in forum DomesticReplies: 3Last Post: 28-01-2008, 08:29 PM -
Efficient Water-Source Condenser Design?
By Enginerd in forum FundamentalsReplies: 4Last Post: 28-05-2007, 05:11 AM -
Senior Design Project
By Kenan.Clay in forum Chit Chat & Service StoriesReplies: 9Last Post: 21-01-2007, 12:44 PM -
Replacement fo CO2 Bulk Tank refrigeration unit
By pabs_ref in forum CO2Replies: 31Last Post: 28-11-2006, 10:32 PM
