Thread: VRV R22 Replacement
31-03-2009, 01:51 PM #1
VRV R22 Replacement
Hi Has anyone used a drop in replacement for R22 in a VRV system? Such as R417a? Thanks for any help.
31-03-2009, 02:02 PM #2
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: VRV R22 Replacement
Why if you still have available R22?
31-03-2009, 02:31 PM #3
Because it is being ohased out at the end of the year and we want to future proof the systems.
31-03-2009, 05:21 PM #4
R417A was originally blended by RHODIA and marketed as ISCEON RX 59, an R22 replacement, suitable for a straight drop-in without changing the mineral oil. It was aimed at the split air-con market. It has been around for 15 years or so and despite the horror stories, I expect that there are numerous installations where this exchange has been carried out quite successfully. R 417A is its ASHRAE refrigerant number.
There are two places to go where I would expect advice: the first are the original manufacturers who must be aware of the legal trends in the EU, secondly the original marketer of the blend. Why not contact RHODIA in the UK?
That said, VRF manufacturers are notoriously conservative about approving (or disapproving) field changes, but they have a duty, I believe, to offer suggestions to this particular problem. In the current market climate, I would, personally, not take 'don't know' as an answer.
.Last edited by Argus; 31-03-2009 at 05:37 PM.
01-04-2009, 11:00 AM #5
DuPont™ ISCEON® MO29 (R422D)
DuPontTM ISCEON® MO29 (R422D) is an easy to use, non-ozone depleting HFC refrigerant blend of R125, R134a and R600a.
ISCEON® MO29 is used to replace R22 in a wide variety of high, medium and low temperature refrigeration applications as well as air conditioning and water chiller systems.
It has also been used in new equipment and selected ‘flooded' applications.
ISCEON® MO29 is a close match to R22 in terms of capacity and efficiency in most systems, but with a significantly lower discharge temperature which may prolong life of the compressor.
ISCEON® MO29 is compatible with traditional and new lubricants, providing easy, quick, cost effective retrofits and can be topped up during service without removing the entire refrigerant charge.
As ISCEON® MO29 is a blend it should always be removed from the cylinder as a liquid when charging a system.
01-04-2009, 07:30 PM #6
about 8 months ago we re-charged an R22 VRV+ system with R417a. No problems to date and running sweet.
01-04-2009, 07:36 PM #7
R22 replacement
By brad__34 in forum RefrigerantsReplies: 28Last Post: 04-06-2010, 09:06 PM -
replacement evap motor... where from ? / identification ?
By knighty in forum CommercialReplies: 14Last Post: 20-11-2008, 10:50 PM -
Ductless Samsung evaporator fan motor replacement
By racktech2008 in forum Air ConditioningReplies: 3Last Post: 05-05-2008, 08:21 AM -
Replacement Screw Compressors
By dkemper in forum Technical DiscussionsReplies: 2Last Post: 13-10-2007, 07:22 PM -
F 11 replacement for flushing
By andrewuk in forum RefrigerantsReplies: 1Last Post: 17-10-2003, 11:03 PM
