Thread: cascade
25-03-2009, 06:09 PM #1
cascade
Hi as some of you may already know i am very new to the comercial side of refrigeration (job forces this) and i have been plodding on quite nicley. I have been told tody that they are getting some Cascade and climate machines machines in on r290 gas. What are Cascade and climate machines as i have googled them and cant find any thing on them??? is it a type or a make?? No one knows any thing at work as i am the only one on the fridge side.
25-03-2009, 06:51 PM #2
Re: cascade
A cascade system is where you have at least two refrigeration system working together.
Because the low side gases run at very high pressures if used with ambient condensers they use the evaporator of the high side unit to cool the condenser of the low side one.
Layout as here...
http://www.essproducts.com/images/image7.gif
Climate machines can be a cabinet with a cooling system with electric reheat to ramp up and down or hold a set, but adjustable, temperature. Often used to test manufactured items.Brian - Newton Abbot, Devon, UK
25-03-2009, 07:41 PM #3
Re: cascade
Many thanks again for the info, not looking forward to trial and error on them
25-03-2009, 08:01 PM #4
Re: cascade
Would you know the typical running preasure's???
25-03-2009, 10:57 PM #5
Re: cascade
Look up a PT chart for R23 to give you some ideas of pressures.
http://www.refrigerants.com/pics/ptchart.pdf
R23 at -28°C is 138psig and about zero psig at -82°C
Have fun.Last edited by Brian_UK; 25-03-2009 at 11:03 PM.
08-04-2009, 02:47 PM #6
Re: cascade
R290 is propane, be careful !!!
r-23 low stage, cascade system
By johnny1 in forum RefrigerantsReplies: 8Last Post: 21-11-2009, 09:01 PM -
R-23 cascade system
By S.M.Gokhale in forum IndustrialReplies: 22Last Post: 08-08-2009, 08:04 AM -
Building a 3 stage cascade
By NoL in forum CPU OverclockersReplies: 9Last Post: 27-03-2009, 08:42 PM -
Refrigerant for multi-stage and cascade systems
By lraja in forum RefrigerantsReplies: 0Last Post: 15-01-2007, 01:27 AM -
Regulation regarding hydrocarbons in an cascade
By DaBit in forum FundamentalsReplies: 4Last Post: 19-01-2004, 12:42 PM
