Thread: Toshiba RBC-SRI PE Controller
24-03-2009, 03:20 PM #1
The unit i am working on comes up in and 09 fault and i think it may be because the temperature is being set down to 18oc and causeing the evporator to freeze. It is located in an electronics testing area and is only meant to provide additional cooling an therefore will not be able to cool the whole area.
Can some one please tell me how to lock out the above mention controller to stop people fiddling with the temperature settings.
Ian
24-03-2009, 10:10 PM #2
Re: Toshiba RBC-SRI PE Controller
Hi Ian
Unfortunatly the only solutions are to either get a lockable perspex box for it or else get a central controller linked up to it, the latter being more likely far too expensive for the application. Only the newer type units have add ons and tweaks that allow this.
30-03-2009, 08:47 PM #3
Hi Ian
As Ian has said the only options are to lock the controller away eithyer in a perspex cover or a secure cupboard or to use either a central controler or an RBC-FDP2-BMS to allow the controller to be locked.
Brit
30-03-2009, 11:25 PM #4
Link to lockable cover....
http://www.heatingcontrolsonline.co....rge-p-343.htmlBrian - Newton Abbot, Devon, UK
01-04-2009, 01:41 PM #5
Thanks for replies,
I Have covered the controller with a notice asking that the controller not be adjusted and enough tape to ensure it doesn't !
So far so good
Toshiba controller flashing check?!?!?!?!
By leety in forum Air ConditioningReplies: 6Last Post: 20-07-2010, 08:45 AM -
Toshiba wired remote controller
By dodger in forum Air ConditioningReplies: 3Last Post: 15-01-2009, 10:50 PM -
Daikin Controller
By mchild in forum Air ConditioningReplies: 11Last Post: 24-11-2008, 02:34 AM
