Results 1 to 2 of 2
Thread: Query
13-03-2009, 12:24 PM #1
Query
I have a question please, I have a condensing unit with a suction and discharge of 2 1/8" and 1 1/8" respectively. Can I reduce the pipe to an extent of say 1 1/8 exp 3/8 on the evaporator. can you please advise if this is OK or what would be the ripercusions if this connection is done. can it burn the winding of the compressor? please if possible e-mail be on r.gera@bartolich.com. Thanks & regards, Ray
15-03-2009, 07:53 AM #2
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: Query
You should do pipe size calculation and then see if that sizes are sufficient or not.
http://www.airah.org.au/downloads/HV...009-02-F03.pdf
Component balancing & cross plots query.
By refca in forum FundamentalsReplies: 0Last Post: 21-11-2007, 11:49 AM -
Kano Seiki 'Oilmatic' Chiller Query
By The Red Krawler in forum Trouble ShootingReplies: 0Last Post: 09-10-2007, 04:53 AM -
Cappilary system query?
By setrad7791 in forum Trouble ShootingReplies: 12Last Post: 10-03-2007, 01:53 AM -
Compressor Query
By archstanton in forum Technical SpeculationsReplies: 3Last Post: 06-07-2006, 05:04 PM -
Foster query
By eam1956 in forum CommercialReplies: 4Last Post: 23-01-2006, 09:37 PM
