Thread: Remove Unit
    Aug 2008
    44
    Remove Unit
    What would the estimated cost factor be to recover 200Ibs of R22 *****, break down and remove this old Carrier unit. I've recovered ***** from smaller units but have never tackled something like this. Some pointers or what to look out for would be great. I've included some pictures. Thanx for the help.
    Smart remarks come from smart people.
    5,667
    Re: Remove Unit
    Recovering refrigerant is the same on a small unit as it is on a big unit - just takes a little longer on the big stuff
    . The way to cost it up is to look at your recovery machine and see how much refrigerant it can handle per hour.
    Multiply this with the estimated quantity in the 'big' unit and add a little for unknowns, bottle hire and expenses. That's assuming you charge by the hour.
    Jan 2009
    Queensland
    65
    113
    Re: Remove Unit
    is the system still working? as in, can you pump it down to the receivers?
    It's a lot quicker / cheaper to get the refrigerant out of the system as a liquid.
    ireland
    1,451
    Re: Remove Unit
    If the water is still connected either ensure the pumps stay running whilst recovering, there should be a shut off valve on the liquid line to enable a partial pump down,this liquid can be drawn off very quickly or pumped directly into the recovery bottles by the compressors.
    al
    Nov 2008
    136
    Re: Remove Unit
    hello,
    if it is a chiller keep both evap and condensor pumps running as it can freeze up and spilt tubes/ tanks
  1. Replies: 12
  2. HITACHI RAS Question
    By mourgos in forum Air Conditioning
    Last Post: 24-09-2008, 10:27 PM
  3. SL/SB-400 Pump Down Procedures
    By absolute-zero in forum Transport
    Last Post: 29-01-2008, 09:27 PM
  4. Thermo King OptiSet
    By REEFER-TEK in forum Transport
    Last Post: 06-12-2007, 07:23 PM
  5. TK basic micro-p features and functions
    Last Post: 05-12-2007, 06:25 PM
