Results 1 to 12 of 12
Thread: Defrost in supermarkets
01-05-2004, 08:09 AM #1
Hi all
I am interested in what systems supermarkets use and what types of defrost is most common gas or elec.
Can someone also explain how the gas defrost works and what would you most commonly find in tescos
Or if you could pass on any links to web sites regarding supermarket refrigeration
Many thanks
Bernard
01-05-2004, 09:14 AM #2
Re: Defrost in supermarkets
HT cases (0-3) say mostly use off cycle defrost by cycling LLSV off for a predetermined air temperature or coil temperature or time.(depends on software used)
LT cases (-18 - -25) say use electric defrost methods by means of finned or rod type heaters.(depends on software used)
Hot gas defrost uses discharge gas from pack to defrost,saturated gas defrost uses gas from the top of the reciever(full explanation/discussion of sat gas defrost in supermarket forum).
The prefered method being electric defrost less controls,less wiring installation times cut,commissioning time less turnover of store quicker .
I cant speak about all tescos equiptment they like many other stores in the supermarket arena have and will continue to use a method which maximizes profits and keep breakdowns to the minimum.
Best regards Mark
01-05-2004, 06:49 PM #3
Hi Mark
I am familiar with the elec and hot gas its the sat/gas I need more info on.As you suggested I,ll search the forum.
Regards Bernard
01-05-2004, 08:24 PM #4
hi guys,
an interesting paper about supermarket refrigeration and defrost systems.
http://www.ornl.gov/sci/engineering_...per_Vasile.pdf
chemi
01-05-2004, 08:26 PM #5
Hi Bernard
Most sat gas sites have been refitted. There are a few about
Best regards Mark
01-05-2004, 08:35 PM #6
Hi chemi
How are you finding the supermarket work.....ok?
Best regards
Mark
01-05-2004, 08:47 PM #7
hi mark.
to be honest, I didnt get there yet. too much work in one rubber factory
700KW trane chillers with a lot of problems. hope to finish it in a couple of days and get to the supermarket.
I will post a picture of the place when I get there.
chemi
01-05-2004, 08:50 PM #8
Ok chemi
Have fun.
Mark
02-06-2004, 09:01 AM #9
Hi, all
we in Russia use electric defrost in SM - everywhere! for Plus Temp and Low Temp Cases.
BR
Andrew
02-06-2004, 12:33 PM #10
Dear Bernard,
for what concerns Belgium (DELHAIZE, CARREFOUR):
It used to be electric defrost as of cabinet temperature of 0°C down to -25°C, with fixed defrost hours (eg : 1.00; 07.00; 12.00; 20.00). This to make sure that no defrosts were activated during the opening hours of the supermarket.
Nowdays electric defrost is still the most common method but since the controllers have been evolving quite rapidly these last years, defrosts are monitored much more closely and activated only when absolutely necesarry !
Niko
03-06-2004, 08:22 PM #11
hi niko,
do you have experience with Dixell i-chill?
chemi
04-06-2004, 07:41 AM #12
Sorry Chemi, but I don't know the Ichill instruments from Dixell. However I took the time to download some doc from the internet and it seems like a basic chiller controller to me...
What's the problem ?
I do know DIXELL well though. I used to be the first distributor outside Italy for their products. As you might know the founders of Dixell are ex-ELIWELL people and I still know them quite well. To be honest, from a technology point of view, they have been quite advanced since they started about 7 years ago (the company was still called SAE at that time).
Bye,
Niko
Hot Gas defrost suction pressure regulation
By 87mustang in forum Technical SpeculationsReplies: 5Last Post: 05-08-2005, 07:25 AM -
Hot Gas vs. Electric Defrost
By herefishy in forum Technical DiscussionsReplies: 26Last Post: 08-03-2005, 07:50 PM -
Electric Defrost
By iceman007 in forum Trouble ShootingReplies: 19Last Post: 12-06-2004, 09:34 AM -
Hot gas defrost
By Volnei in forum FundamentalsReplies: 2Last Post: 18-05-2002, 12:26 PM
