Thread: tk sea container
21-02-2009, 06:19 PM #1
tk sea container
Hi everybody this is my first posting
Can you help me with a TK sea container that will not control at set point +4
The liquid line solenoid will not shut power to it all the time if you remove the coil the unit pumps itself down but will not cut out on Lp
Does this make sense?
It has i think two faults?
21-02-2009, 10:10 PM #2
Re: tk sea container
Sounds like the LP is setw rong or has been linked out.
22-02-2009, 11:37 AM #3
maybe the solenoid has also been bypassed and its running straight from the stat
22-02-2009, 08:35 PM #4
Do you know the exact model of the unit.
24-02-2009, 01:45 AM #5
it could be the lpco is bypassed already, but the exact model number would help us all out.
27-02-2009, 06:52 AM #6
I think, you should check 24v power output from MRB ( for MP3000 ) to coil first.
It seems LPCO jumped.
06-06-2009, 12:33 PM #7
Hi guys sorry foR the long delay in replying but have been very busy
the container is a CF11 M19.7
the unit will not control at set point +4 unit pumps itself down but will not cut out on lp no voltage coming out of the mirco p i have changed the lp last year what is the next step?
Carrier container problem
By Shamel in forum TransportReplies: 13Last Post: 19-03-2011, 01:25 PM -
Cooling down the water in a 1000 liter container
By Joep Hogenhout in forum Technical DiscussionsReplies: 29Last Post: 21-04-2009, 01:27 AM -
Reefer container
By stevec in forum CommercialReplies: 2Last Post: 25-01-2009, 05:30 PM -
Freezer Container
By mohamed didi in forum Trouble ShootingReplies: 5Last Post: 16-08-2007, 08:34 AM -
Container Data info
By Paulajayne in forum Technical DiscussionsReplies: 7Last Post: 06-06-2007, 02:51 PM
