Thread: Replacement Stat
09-02-2009, 03:47 PM #1
Replacement Stat
Could anyone tell me if there is a replacement milk stat for ice bank bulk milk tanks, the one that we were using was a white roger stat(Fabdec supplied)
but now are no longer available.
Any assistance will be greatfully accepted
Kind regards Mark.
09-02-2009, 06:45 PM #2
Re: Replacement Stat
Hi catcher,
I found these were obselete the other week when trying to replace van stock. Many mechanical stats have too wide a differential for milk cooling applications, but i remember years ago fitting a Penn thermostat on an old mueller dx tank and i had planned to see if one of these wold fit instead, but have done nothing so far
If not i guess it'll be some electronic one that'll need a contactor and the probes replacing every five minutes.
Jon
14-02-2009, 11:28 PM #3
From memory I think you can get one from RPW ...
Regards, Trevor
14-02-2009, 11:29 PM #4
cant you just fit a ranco diff stat?
ice maker masterfrost c800 ice thickness stat??
By gazcull in forum CommercialReplies: 2Last Post: 16-02-2008, 08:37 PM -
Replacement Screw Compressors
By dkemper in forum Technical DiscussionsReplies: 2Last Post: 13-10-2007, 07:22 PM -
Changing a stat
By jamboice in forum DomesticReplies: 2Last Post: 12-09-2006, 05:09 PM -
Replacement stat
By Lucas in forum DomesticReplies: 13Last Post: 02-08-2006, 11:28 PM -
Freeze stat sensor
By cooltrain in forum TrainingReplies: 5Last Post: 06-08-2003, 07:58 PM
