Thread: Marrelli compressor
06-02-2009, 11:00 AM #1
Marrelli compressor
Hello guys,
I'm desperately looking for a manual for a Marrelli compressor.
It is for a ship that is in the Rotterdam harbour now and leaves on monday.
I googled it but I keep geeting hits for magneti marrelli that deliveres for the automotive sector.
De manual i need is for the following type:
Make: Gruppo ind. ercole Marrelli S.P.A
Model: CHC 075AHF1
Ser. Nr. 9-A-16-15
Displacement: 244 m3/h
Velocity: 151 c-1
Made in Italy
Thaks in advance if anyone can help me.
Greetings,
Bart nabbe
06-02-2009, 03:39 PM #2
Re: Marrelli compressor
Barte.
I have drawn a blank also.
But I have tracked them down to possibly part of the Sundyne Corporation of U.S.of A.
I have registered with them and if it is cleared in time and I find anything I will post!
06-02-2009, 06:07 PM #3
Hello barte you wont find a manual for marrelli compressor because its changed so many names,its same as worthington 3v and the refcomp src f and fedders and klima , the mechanics are same but the o rings in the liner for unloaders are slightly thicker and you can get spares from cmp corporation
06-02-2009, 06:55 PM #4
Hello again barte for rebuilding or teardown info ,be careful because the rods and pistons go through the crankcase and up in to the liners and the unloading liners have a like a golfers teefor oil , if its a semi then the main bearing housing is fitted to the motor barrel and the motor barrel is fitted to the main crankcase, the stator is slide fit, the unloaders come in and out very slow because of small orifice. hope this is enough for you
08-02-2009, 09:42 PM #5
It is indeed a Semi. I forgot to put in the specifications.
I have a picture that i can post if that helps anyone to help me hahahaha.
Greetings,
10-02-2009, 08:24 AM #6
Marelli is no longer in business since 20 years. It was later owned by Seveso Clima, but indeed as Ghaz say, refcomp copied the design, so chances are that a spare part of Refcomp may be used on Marelli.
LG heat pump problem
By back2space in forum Heat PumpsReplies: 132Last Post: 01-02-2009, 11:23 PM -
compressor / electrical problem
By Northdude in forum CommercialReplies: 6Last Post: 17-01-2009, 10:24 AM -
SL/SB-400 Pump Down Procedures
By absolute-zero in forum TransportReplies: 1Last Post: 29-01-2008, 09:27 PM -
Compressor pumping efficiency
By shogun7 in forum FundamentalsReplies: 0Last Post: 25-02-2004, 10:50 PM
