05-02-2009, 01:11 AM #1
Escort Compressor Check Valve Explanation
Cheers, the rack has three compressors with common liquid. The escort compressor is seperated from the suction header via check valve. My escort covers the ice cream (14psig @ HP80) where the remaining compressors take care of frozen food @ an average of 25psig. Can anyone explain the check valve operation?? Thanks
05-02-2009, 10:12 AM #2
Re: Escort Compressor Check Valve Explanation
the check valve is like an emergency crossover to the main suction group on the rack. If the suction pressure in your satellite (escort) suction group rises to the pressure of the main suction group refrigerant will be allowed through the check valve and the load will be taken up by the main suction group - it is also useful in coping with high load situations like defrost pulldown
...and she said "give it to me you big fridgie"
06-02-2009, 08:00 AM #3
yup, the Suction Compressors can aid the Satellite but not the other way.
Sporlan subcooling valve
By BESC5240 in forum Technical SpeculationsReplies: 8Last Post: 13-10-2008, 03:23 PM -
R22 Flooded System - Trawler
By chiefbecker in forum System OptimizationReplies: 18Last Post: 07-02-2008, 11:11 PM -
Compressor valve test
By RackMechanic in forum Air ConditioningReplies: 11Last Post: 03-02-2008, 05:57 PM -
Benji
By benji in forum Trouble ShootingReplies: 29Last Post: 30-01-2008, 01:25 PM -
TEV with MOP: how to keep valve body temp above bulb temp?
By DaBit in forum FundamentalsReplies: 5Last Post: 16-10-2002, 12:38 AM
