Results 1 to 2 of 2
23-01-2009, 11:33 AM #1
Heat pump with inverter technology for Motorhomes
Had a request on another forum whereas the op is wanting to put a standard split system onto the back of a motorhome. I have advised this would not be safe due to the weight and how the outdoor units stick out, you would not be able to drive on the road with it I dont think.
DOes any one know of any companies that can fit out motorhomes with purpose designed heat pump inverter systems for motor homes?
Richard.
23-01-2009, 11:58 AM #2
Re: Heat pump with inverter technology for Motorhomes
Have a look at the coleman mach III
Capacity control
By sparrow in forum TrainingReplies: 44Last Post: 18-01-2010, 07:49 PM -
DIY heat pump 12kW
By kimusabi in forum FundamentalsReplies: 11Last Post: 17-10-2009, 07:50 PM -
Samsung Smart Inverter heat pump
By muskyman in forum Trouble ShootingReplies: 1Last Post: 31-10-2008, 06:23 AM -
panasonic inverter heat pump in new zealand
By otto2008 in forum Air ConditioningReplies: 6Last Post: 05-09-2008, 07:04 AM -
frostles heat pump
By Lc_shi in forum New TechnologiesReplies: 27Last Post: 31-03-2008, 07:53 AM
