Threaded View
13-01-2009, 01:38 PM #1
Wrong temperature on control panel
Hi there!
I've got a Bosch KGU3201 frost-free fridge freezer, bought in 1997.
The freezer part works fine, but the fridge has a problem:
The temperature in the fridge is much warmer than the one displayed on the control panel. When the display shows the required temperature of e.g. +4 degrees, the cooling stops, although the actual temperature is still about +12 degrees (which is the ambient temperature).
To check, I set the temperature from +4 degrees to the lowest possible temperature (+2 degrees). The fridge worked for a few minutes (I could hear the coolant flow when I put my ear against the side) and the water droplets on the interior rear panel of the fridge compartment became frozen. But as soon as the control panel displayed +2 degrees, the cooling stopped and the frozen film very quickly thawed again. All the time, the actual temperature in the fridge was nowhere near 2 degrees, but closer to 12 degrees.
The fridge is about a quarter full and air can circulate freely. I also make sure that the area right next to the temperature sensor is kept free. The drain hole in the drainage gutter is unobstructed.The seals around the door are clean and undamaged.
The call-out fee for a Bosch engineer literally costs as much as my monthly food budget. Is there a way I can repair the problem myself? My gut feeling is that the problem might lie with the sensor.
Could you give me some advice, please?
Superheat and Subcooling
By Chunk in forum FundamentalsReplies: 42Last Post: 15-01-2011, 01:24 AM -
Thermo King OptiSet
By REEFER-TEK in forum TransportReplies: 4Last Post: 06-12-2007, 07:23 PM -
TK basic micro-p features and functions
By REEFER-TEK in forum TransportReplies: 0Last Post: 05-12-2007, 06:25 PM -
Article in ACH&R News
By Gary in forum FundamentalsReplies: 8Last Post: 20-05-2003, 12:27 AM
