Thread: Need code for samsung AQV12FCN
10-01-2009, 11:04 PM #1
Hi ,
i Need code for my A/c i have search the posts but no luck with this model
By the way turbo and timer led are blinking. So it is communication problem, any suggestions and will new code do the trick ?
11-01-2009, 10:38 PM #2
Re: Need code for samsung AQV12FCN
Nobody ?
11-01-2009, 11:21 PM #3
I thought that the option codes was only for resetting the unit after a power down.
12-01-2009, 08:53 AM #4
Hi, Brian_UK
well i don't know, i thought that those codes are for reseting unit, after power down or some errors ??? Any way some guy is coming today to fix it.
12-01-2009, 04:52 PM #5
14-01-2009, 06:00 PM #6
Thanks to all , but problem was so simple, installation guy forgot to connect communication wire can't believe
Hitatchi Fault Code F 05 04 ?
By andycc in forum Air ConditioningReplies: 1Last Post: 03-03-2008, 10:02 PM -
lennox fault code
By richelli in forum Trouble ShootingReplies: 0Last Post: 01-02-2008, 09:13 PM -
A6 Fault Code Problem
By markcubed in forum Air ConditioningReplies: 3Last Post: 29-12-2007, 11:29 AM -
mitsubishi city multi fault code
By robin r33 gtr in forum Air ConditioningReplies: 5Last Post: 05-11-2007, 10:23 PM
