Results 1 to 9 of 9
    Mar 2004
    Pittsburgh
    13
    Temperature control
    I have one freezer with redundant condensing units. As is, each unit is controlled by it's own thermostat.Naturally one sys. becomes the lead and the other the lag. Is there an easy way to equalize run times between each unit?
    11,025
    Re: Temperature control
    Quote Originally Posted by Matt
    Matt are you looking for a 'cheap' method or an all singing and dancing 'expensive' system ?
    Mar 2004
    Pittsburgh
    13
    I'm sure the customer would say a cheap method.They have that reputation!I prefer something reliable, whatever the cost.I can give them a proposal for both senarios.
    11,025
    Matt, what we have done in the past is construct a lead/lag changeover control which can be either a simple hand switch, (1 or 2), or you could perhaps integrate a timeswitch changeover.
    Thinking back, I seem to remember someone creating an auto changeover switch which activated everytime (or every several) the thermostat called.
    shogun7's Avatar
    shogun7 Guest
    Sep 2003
    ISRAEL
    72
    4,248
    hi matt,
    its simple to make a control system that based on simple, relable, weekly timers,
    how many condensing units do you have?
    let me know and I will make you a diagram.
    chemi
    Apr 2001
    79
    5,071
    35
    I recall seeing auto changeover switches on dual air compressors. Each time a compressor is needed it changes over.
    Mar 2004
    Pittsburgh
    13
    I have two cond.units per freezer.
    Atotal of two freezers!
    Oct 2003
    5,630
    34
    Why not using a simple Logo of Siemens?
    This is a (very) low cost PLC, easy to program.
    Did it many times in the past and is in py opinion the cheapest solution.
    The logo will count the hours the real compressor running hours and they will switch at the moments you programmed them.
    We used it to reverse the condensor fans to remove leafs of trees from the underside of condensors. (Sort of autocleaning)
    Have a look at http://www.ad.siemens.de/logo/index_76.htm and you even can download a demo software to play a little bit around.
    Crouzet introduced some weeks ago a comparable product but with tge possibility of analog in/out (0-10 V or 4-20 mA), mobilephone alert modules, fax modules, wireless links.... an amazing piece of electronic.
  1. re ref. circuit
    By shsalameh in forum Fundamentals
    Last Post: 06-08-2007, 12:59 PM
  2. Q=? h1=? mechanical schematics
    By fridg in forum Technical Speculations
    Last Post: 19-03-2006, 01:43 PM
  3. Heat pump temperature control
    By Vincent Yu in forum Fundamentals
    Last Post: 30-09-2005, 12:50 PM
  4. New Capacity Control Solution
    By embrown in forum New Technologies
    Last Post: 30-12-2003, 01:33 PM
  5. Article in ACH&R News
    By Gary in forum Fundamentals
    Last Post: 20-05-2003, 12:27 AM
