Results 1 to 2 of 2
Thread: Bitzer compressors
18-03-2004, 02:04 PM #1
Bitzer compressors
Is anyone out there having problems with Bitzer 4H compressors burning out , particularly on medium temperature applications???
18-03-2004, 03:03 PM #2
hi guy,
the 4H range should work fine with medium temp.
I think the problem might be in the electrical side.
do you start them direct or part winding?
do they get hot at work?
I had once a similar problem, chaged the start to direct and the problems gone.
I use them for many years without any special problems.
chemi
Bitzer gasket
By Renato RR in forum FundamentalsReplies: 5Last Post: 04-11-2010, 10:08 AM -
Bitzer Octagon compressors
By RONB in forum Supermarket RefrigerationReplies: 25Last Post: 31-10-2010, 08:33 AM -
Bitzer s6f30 2-stage compressors
By JONAH in forum Technical DiscussionsReplies: 25Last Post: 27-10-2010, 07:27 AM -
Compressor's volume efficiency
By John McGru in forum FundamentalsReplies: 0Last Post: 16-02-2004, 08:44 AM -
Comparative compressors
By Friobernal in forum Technical DiscussionsReplies: 7Last Post: 28-04-2002, 07:21 PM
