07-12-2008, 02:52 PM #1
ned help for calorex swimming heat pump
hi every body can you help me to solve a problems of copeland compressors.
compressor brand :copeland scroll
model : zr12m3e-twd-551
type : scroll
oil recommended oz.140 poe
refrigerant ;134a
i removed gas, vaccuam 2hrs. add oil suniso sl68.
charged gas. run the unit. the resut is high pressure and high amp.
my ? is what is the problem of like this result.why high amp and pressure. there is any problem that for replaced oil. what ctual gas pressure of 134a.
i put 30 to 35 psi.how i can solve this problem.can you give me full steps of recover this unit.
i will thankfull for your kind help.
TRY TO LEARN MORE ABOUT A/C SYSTEM
07-12-2008, 02:54 PM #2
Re: ned help for calorex swimming heat pump
type : scroll
refrigerant ;134a
__________________
07-12-2008, 11:51 PM #3
07-12-2008, 11:54 PM #4
Why did you remove the gas and charge with oil?
Capacity control
By sparrow in forum TrainingReplies: 44Last Post: 18-01-2010, 07:49 PM -
DIY heat pump 12kW
By kimusabi in forum FundamentalsReplies: 11Last Post: 17-10-2009, 07:50 PM -
frostles heat pump
By Lc_shi in forum New TechnologiesReplies: 27Last Post: 31-03-2008, 07:53 AM -
swimming pool heat pump
By Andy AC in forum The Trail of TearsReplies: 8Last Post: 26-08-2007, 04:02 PM -
Heatstar swimming pool heat pump
By Latte in forum Trouble ShootingReplies: 9Last Post: 28-06-2007, 06:15 PM
