27-11-2008, 03:57 AM #1
Thermoking CSR40_MPD_temp pulldown too slow
HI All,
I have problem to solved TK CSR40 microPD unit (reefer container ) which has cooling down problem.
These parts have been replace ( TXV, LIV coil, clean up system, recharge refrigerant ) Problem hasn't solved yet.
Please help
Brgds
Teguh
06-12-2008, 12:10 PM #2
Re: Thermoking CSR40_MPD_temp pulldown too slow
re evap. fans running right direction.
reefer
06-12-2008, 12:11 PM #3
have you checked for alarm codes
does unit complete full auto PTI
reefer
07-12-2008, 03:47 PM #4
Why were those parts replaced ?, did they test bad ?
What is your modulation valve doing ?
And like Reefer said, does it pass PT ?
I'm ASSuming it won't, so at what mode does it fail in and what alarms do you receive ?
Head pressure ?
Suction pressure ?
DT temp ?
Super heat reading ?
09-12-2008, 04:31 AM #5
Hi Will and reefer,
Thank for your reply.
The evap motors are run right direction. No alarm appear during PTI, but temp goes down too slowly while precool step.
The problem has been solved. It was caused by microprocessor failure.
B Rgds
Teguh
LG heat pump condensor fans slow running
By Mickvee in forum Trouble ShootingReplies: 12Last Post: 22-11-2005, 08:17 AM
