Results 1 to 2 of 2
Thread: Scotsman AC125
25-11-2008, 05:41 PM #1
Scotsman AC125
I have an AC125, for a while it has been producing half its full output. After defrosting the spraybar it is struggling to produce any.
Is there a simple fix, or is it time to buy new?
25-11-2008, 06:25 PM #2
Re: Scotsman AC125
Ac125's are normally VERY reliable.
Couple of things to check.
In the middle of the PCB should be a light which say's in the board -12. Check to see if this light is coming straight on as if it is you may have a problem. The freeze cycle times from the moment this light comes on so if its getting a faulty reading for some reason then all else fails. Poss the area of the coil where the probe is is iced up. Also do you live in a high limescale area. do you have filters on the water inlet, has the unit been flushed with descaler recently.
Whatever details you can tell us helps but i dont think its time to buy another one yet
Scotsman DCE33 icemaker
By skidog in forum Trouble ShootingReplies: 4Last Post: 09-04-2008, 01:14 PM -
Need info on the shaft seal system for scotsman
By The MG Pony in forum CommercialReplies: 4Last Post: 17-03-2008, 02:02 AM -
Scotsman SCE-170 Weird Situation
By KenInEastTX in forum Trouble ShootingReplies: 3Last Post: 12-11-2007, 01:39 AM -
scotsman ice-machine
By yourxmen2910 in forum Technical DiscussionsReplies: 7Last Post: 28-08-2006, 10:21 AM -
Scotsman Ice Making Machine.
By Latte in forum Trouble ShootingReplies: 10Last Post: 01-09-2004, 10:16 PM
