Thread: AHU Integral Cooling System
18-11-2008, 07:34 PM #1
Hi All
Does anyone out there have any info on design of dx cooling integeral to an ahu.
Coolkids
18-11-2008, 10:09 PM #2
Re: AHU Integral Cooling System
Are you after the physical design of the coils etc or the calculations required to get the coil duties?
19-11-2008, 08:23 PM #3
Hi Brian
The coil design I can do. its more the pipe work set-up
I found a great compressor selection tool on the emerson climate site . www.ecopeland.com
regards
Coolkids
Daikin fault codes
By Chris2005 in forum Air ConditioningReplies: 45Last Post: 21-03-2012, 10:09 PM -
System Burn Out Troubleshooting
By altaf22m in forum Technical DiscussionsReplies: 13Last Post: 07-05-2010, 09:24 AM -
charging a system
By shaun26 in forum FundamentalsReplies: 14Last Post: 24-03-2008, 01:58 PM -
Cooling tower evaporation, blowdown, makeup and cycles
By miltbeychok in forum FundamentalsReplies: 0Last Post: 13-10-2005, 05:14 AM -
Automotive A/C Vent Temp Range vs System
By Don Browney in forum Air ConditioningReplies: 1Last Post: 15-05-2002, 06:19 AM
