Results 1 to 12 of 12
    Sep 2008
    South Africa
    67
    5
    Anti sweat heaters
    Hi All, I have come across anti sweat heaters in cabinets that have a diode connected in series with the 220v supply. I have also come across other cabinets that have a capacitor connected in series with the 220v power supply. I have been informed that the purpose of these are to limit the heat. If this is the case can anyone please explain how this is achieved (thechnically). Thanks
    Jan 2006
    Re: Anti sweat heaters
    The diode reduces the heat from the anti-sweat heaters because it reduces the current through the heaters.
    The diode blocks part of the AC cycle and the average voltage across the heaters is reduced.
    A capacitor does a similar thing, there is a voltage dropped across the capacitor which reduces the available voltage across the heaters and hence, less heat output.
    Sep 2008
    South Africa
    67
    5
    Smile Re: Anti sweat heaters
    Thanks for your reply walden,. What value diode and capacitor would you use? Feeze
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by freezemo View Post
    Diode should be of amperage rating higher than I=U/R
    where U is power supply voltage, and R is resistance of heater (when on working temperature) or, I=P/U where P is power of heating element and U is power supply voltage
    http://www.allaboutcircuits.com/vol_2/chpt_4/3.html
    Sep 2008
    South Africa
    67
    5
    Thanks nike123 for thi solid information. The unselfish sharing of information is what I love about the forum Regards, freezemo
    11,025
    Say Nike, that is a very useful website, thank you.
    Jan 2006
    Freezemo, you’ve got the basics for the rating of the diode all I’d add is the “Law of Two”. If, for instance the heaters are taking 1A, use a diode rated at least 2A and if the voltage is 220V, as it is in your case, use a diode rated at least 400V. The extra cost is insignificant, diodes cost pennies, but the increased ratings will help prevent failures from voltage spikes or short circuit currents.
    The size of the capacitor is more involved. You have to calculate the impedance need to drop the voltage. Use a 400V type and, for extra protection, use one labelled “X” or “X2” these are give much better protection against voltage spikes.
    If I were you, I would stick with the diode! It’s easier to install and it doesn’t matter, on an AC supply, which way round you fit it!
    Have a good weekend!
    Sep 2008
    South Africa
    67
    5
    Thumbs up Re: Anti sweat heaters
    Thanks walden. I appreciate your detailed explanation and wish you likewise. Cheers,freezemo.
    Nov 2008
    Slovenia
    34
    I'd advise you to install a resistor paralel to the capacitor to discharge it when the unit is turned on. 1MOhm should do the job great.
    Sep 2008
    South Africa
    67
    5
    Quote Originally Posted by Pyr0Beast View Post
    Hi Pyr0Beast, I have come across capacitors that are used as start capacitors on single phase compressors, These capacitors also have a resistor connected in parallel.I understand its function is to discharge the capacitor when the power is switched OFF. You state that it is used to discharge it when the unit is switched ON. Is my understanding of the function of the resistor in this application incorrect or did you make a typing error? Sorry if I come across as being rude but I just want clearifacation. Thanks,freezemo
    Split Croatia
    57
    6,151
    36
    You are right, they are used to discharge capacitor when power is switched off.
    Nov 2008
    Slovenia
    34
    Oh, yeah, such a big typo. I meant off, but was thinking of adding something and mixed things up (morning hours :P), sorry. Thanks for correcting me. Should get it right this time I'd advise you to install a resistor paralel to the capacitor to discharge capacitor to non dangerous levels, once unit is turned off and to prevent current rush when unit is turned on with capacitors facing the opposite charge. Capacitors will limit the current passing thru in both directions, this kind of limiting is sometimes unwanted because it causes bad cos fi which unnecessarily loads the network. Sometimes diodes in heaters are used to 'convert' 110V heaters to 220V ones. It depends on how powerful those heaters are (total), 2kW should be acceptable, with more, you should position diodes on the heaters to employ both, upper and lower cycle of the voltage to prevent voltage spikes in the network.
  1. Flame Proof heaters for the drain pan
    By smpsmp45 in forum NH3
    Last Post: 28-06-2008, 12:34 PM
  2. Defrost Heaters
    By jb4393 in forum Trouble Shooting
    Last Post: 29-05-2008, 01:06 AM
  3. Removing sweat on Filter Dryer dangers?
    By mooka in forum Domestic
    Last Post: 09-10-2007, 05:09 PM
  4. Crankcase heaters on splits?
    By Makeit go Right in forum Air Conditioning
    Last Post: 12-06-2007, 08:16 PM
  5. Searle Evaporator Heaters
    By Abe in forum Commercial
    Last Post: 31-12-2005, 10:24 AM
