Results 1 to 2 of 2
Thread: Technical Question re freezer
08-11-2008, 06:49 AM #1
HI, I would like to know one very important thing that " if im using 4.9 MM fin & tube type cindensor for a low temp application (Freezer). but after comp. discharge i use a 6.35 mm 200 mm long tube to joint condensor. What will the effect bocoz of 6.35 tube joint on the system. when i use i found that tamp. is taking more time then normal. pl. explain what is it ????
ThanksLast edited by chillin out; 09-11-2008 at 08:34 PM.
08-11-2008, 07:07 PM #2
Re: Technical Question re freezer
effect should be null if you did all ells properly, ie: sheilding gas, deburring, vacuuming to 200microns or lower.
I would wager your issue is a thermal one, ie; Unbalanced system.
That or charge issue, You should perform an audit of the system, good learning tool.
Air in, air out, coil DT, SH, SC of the evaperator & condensor coils and this will tell you how they are working
Hotpoint FFA71 Freezer High Temp Light / Fridge is Freezing
By sumnerpa in forum Trouble ShootingReplies: 1Last Post: 19-08-2008, 03:16 PM -
Freezer efficiency questions
By M_Q in forum FundamentalsReplies: 8Last Post: 20-03-2007, 04:38 PM -
Technical question
By SIGNSTU in forum Trouble ShootingReplies: 7Last Post: 11-02-2007, 01:26 PM -
A question about walk-in freezer flooring
By kengineering in forum CommercialReplies: 3Last Post: 26-01-2006, 12:34 AM -
By kengineering in forum CommercialReplies: 0Last Post: 25-01-2006, 01:35 AM
