Results 1 to 50 of 596
21-07-2011, 08:54 AM #1
Re: all reefer container problems/daikin/carrier/thermoking/mitsubishi
Hi reefer mechanic,
Just to ask you about SMV of reefer containers what will happen to the temperature if the SMV does not fully close while the fregiration system is running?
21-07-2011, 10:03 AM #2
Hi Avicente,
When did you see SMV fully close ? SMV dosn't fully close never while the refrigeration system running. SMV does modulation cool when reefer working.
What you want learn about SMV? If SMV fully open every time while the refrigeration system running thas big problem...
Waiting your reply.
see you
reefer mechanic..
Container Reefer Unit for Controlled Atmosphere (CA)
By reeferman in forum New TechnologiesReplies: 9Last Post: 26-08-2011, 09:26 AM -
Help cutting open 40ft reefer, we now have problems
By adrian_uk17 in forum IndustrialReplies: 50Last Post: 28-11-2010, 08:11 AM -
Reefer container
By stevec in forum CommercialReplies: 2Last Post: 25-01-2009, 05:30 PM
