Results 1 to 50 of 596
04-04-2011, 03:44 PM #1
Re: all reefer container problems/daikin/carrier/thermoking/mitsubishi
Hi. Could someone help me identify this ThermoKing model? I know it uses a C201 engine and V style (two piston?) pump.
I can not find the location of the model number.
Here is a picture.
It was involved in a cabin fire and the fuel lines melted. I am rerunning the fuel lines but I do not know which line is the return and which is the supply. I would think the supply would go through the filter first. The only place I see this is possible is at a T near the filter, there is a line from the injectors going to one side of this T, The fuel filter is on the other side of the T, and one of the burn off lines at another point on this T.
The other place is on the diesel pump, right under the priming plunger, there is another line that is burned off, but this line does not go to the filters, so I think it is the return line.
what has me confused is the T by the filter. I guess the return from the injectors could possibly refeed into the supply and be refiltered.
04-04-2011, 08:03 PM #2
the fridge in picture is a snwd 30 = no electric standby
Container Reefer Unit for Controlled Atmosphere (CA)
By reeferman in forum New TechnologiesReplies: 9Last Post: 26-08-2011, 09:26 AM -
Help cutting open 40ft reefer, we now have problems
By adrian_uk17 in forum IndustrialReplies: 50Last Post: 28-11-2010, 08:11 AM -
Reefer container
By stevec in forum CommercialReplies: 2Last Post: 25-01-2009, 05:30 PM
