    Jul 2008
    London
    848
    High air volume out a little hole.
    We are fitting a 2kw condenser in a cellar but -and it is a big but- we only have 100 dia in and out drain pipes to the outside(both are only 500mm long) for ventilation.
    Would it be possible to fit a big fan on each to give sufficient airflow -or can any one think of a way to get enough air in/out to keep the condenser satisfied? Bearing in mind it will be cycling anyway so the heat is not constant but the fans will be...
    Multisync
    London
    Feb 2007
    2,473
    45
    Re: High air volume out a little hole.
    Yes fitting fans designed for the right static pressure and volume required sounds like a good idea.
    But why would the fans run permanently?
    A thermostat and a relay would control them according to the requirements, surely?
    Jul 2008
    London
    848
    Quote Originally Posted by The Viking View Post
    Ah yes, I suspect we will need a heat/cool stat for heatpumps..
    Multisync
    London
    11,025
    Just fit a relay to switch the fans in line with the compressor contactor.
    Jul 2008
    London
    848
    With an inverter?
    Time to put away old thinking..
    Multisync
    London
    11,025
    Quote Originally Posted by multisync View Post
    With an inverter?
    Multisync
    London
    and I was expected to know that how ???
    A word of caution with heat pumps indoors.
    I came across a site some time back that had fitted a HP inside complete with drain tray underneath to catch the defrost water which then drained into a tanked condensate pump (Little Giant).
    When in heating mode the area got so cold that the drained water began freezing. The drain tray turned into a block of ice and the freeze up continued down to the pump unit.
    Whenever the unit was turned off and the ice could melt a little they ended up with a flooded room.
    edit: I knew I'd written about this before and with a photo...
    http://www.refrigeration-engineer.co...ight=heat+pump
    Jul 2008
    London
    848
    Coz it's 2008 and not 1968!
  1. need help! compressor kicking out on high pressure
    By SloFuse in forum Trouble Shooting
    Last Post: 19-08-2009, 04:46 PM
  2. How to Design Refrigeration Systems
    By US Iceman in forum Fundamentals
    Last Post: 24-07-2008, 04:27 PM
  3. Compressor loading, cooling, and range of operation.
  4. high volume flow rate
    By cakabo28 in forum Technical Discussions
    Last Post: 04-10-2007, 03:41 AM
  5. fun quiz
    By Brian23 in forum New to RE
    Last Post: 02-10-2007, 10:18 PM
