Results 1 to 25 of 25
    Feb 2007
    oldham
    49
    44
    faulty EPR on coldroom
    got a coldroom running off a pack,temp not dropping below 7 degrees,coldroom has 2 searle evaps and they are just sweating at the exp valves,EPR on top of coldroom a block of ice,adjusted it the other day and coldroom ran fine for 2 days,pressure at EPR 75p.s.i,EPR will not adjust and in my mind is goosed,would it matter if i linked it out or would it be best to replace with new,advise please.........
    Split Croatia
    57
    6,151
    36
    Re: faulty EPR on coldroom
    Ignore!.....
    Feb 2007
    oldham
    49
    44
    not that simply when it keeps triggering a rdm alarm........
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by fazzamouse View Post
    I mean ignore my post because there is no possibility for me to erase it!
    scotland
    756
    is this a m@s site?
    Apr 2001
    79
    5,071
    35
    ... pressure at EPR 75p.s.i,...
    Telling us the pressure is meaningless if we don't know what refrigerant is in the system... and we would need to know the pressure both upstream and downstream from the EPR.
    Aug 2007
    26
    I'm sure Fazza is the person who got a job with City recently. Without checking the old thread im not certain.
    Anyway as Gary says, we need more info.
    Feb 2007
    oldham
    49
    44
    pack is on 404a,pressure at condensing unit is 50p.s.1,pressure at EPR 75p.s.1,sorry not got reading at evaporator will check that on monday when i return.
    Apr 2001
    79
    5,071
    35
    Are there any devices between the EPR and the condensing unit that might be restricting? It's possible that there might be a SORIT valve or similar device at the suction manifold.
    Will the EPR adjust to a higher pressure?
    Feb 2007
    oldham
    49
    44
    the epr is open fully no adjustment left,no other devices between epr and unit,pack runs about 20 metres of multidecks and 2x coldrooms,just getting high temp on this coldroom
    Apr 2001
    79
    5,071
    35
    Does adjusting it in the other direction change the pressure? If it will adjust above 75psi but not below, then the inlet is restricted.
    Jan 2008
    Kent UK
    49
    514
    Are we talking about an electronic EPR? And is the frost just on the pack side of the valve?
    If it ain't broke, it doesn't have enough features yet.
    Damo
    Feb 2007
    oldham
    49
    44
    just your standard alan key adjusting value,the best i could get it to adjust to at epr on friday was 58p.s.i,just dialled into store and coldroom back at temp,****y e.pr?
    Aug 2007
    26
    If its your standard Danfoss EPR that they tend to install in this country then it sounds like its fubar. You should be able to wind that sucker right down.
    Somerset
    69
    4,698
    If its just a case of poor suction pressure control.
    Change the epr as it sounds as if it's passing.
    Do not bypass it!
    Jan 2008
    Norfolk - England
    95
    Sounds like the suction pipe between cold room & pack is too small or overloaded! 25psi pressure drop is excessive..
    possibly it may be the scenario that when other decks go offline the suction pipecopes with the load.
    Billy Ray
    scotland
    756
    do not bypass this epr you really must change this for new as your room will be operating at diff temp from the multi decks so instead of fitting a satilite system to the pack you install epr valves to achive the presure change you will also find this a lot on fresh meat cases on packs
    Feb 2007
    newcastle but now carlisle
    195
    wat is the pressure range on the epr ? it will say on the body .ie 0-60 psi ?
    it could be the inserts in the tevs .are to big ?
  19. #19
    Feb 2007
    195
    tevs may have been adjusted to much
  20. #20
    Feb 2007
    195
    75 psi would giv you a evaporating temp of about +1.no way will the room come down to temp.50 psi about -8,it looks like its u/s to me . fit a new valve
  21. #21
    sydney australia
    8
    Quote Originally Posted by Billy Ray View Post
    Billy Ray
    The EPR is the restriction. There is obviously a problem with the valve. The EPR's job is to restrict flow to raise the backpressure to the required SET of the Room.
  22. #22
    Apr 2001
    79
    5,071
    35
    We need the pressures both before and after the valve, because the upstream pressure can't get any lower than the downstream pressure no matter how much you adjust it.
    For example, if for some reason the suction pressure at the condensing unit goes up to 100psi, then the EPR pressure will go up to 100psi, regardless of the setting.
  23. #23
    Jul 2001
    Sydney, Australia
    753
    Quote Originally Posted by andyrobbo View Post
    andyrobbo is in da house!!! when do you lob in sydney again pugz?
    ...and she said "give it to me you big fridgie"
  24. #24
    Feb 2007
    195
    Gary it does say in 1 of his posts
  25. #25
    Apr 2001
    79
    5,071
    35
    Each time he tells us the upstream pressure, we also need to know the downstream pressure.
  1. new coldroom installation
    By chilltech in forum Fundamentals
    Last Post: 23-07-2009, 05:38 PM
  2. Ice Maker (Nice Ice) Faulty: Help!
    By ArthurLeigh in forum Commercial
    Last Post: 25-10-2008, 10:49 AM
  3. 0C Coldroom Evaporator operating at 20C
    By samiam in forum System Optimization
    Last Post: 29-09-2008, 11:24 PM
  4. problems with coldroom icing up
    By goody in forum Trouble Shooting
    Last Post: 28-03-2008, 06:26 PM
  5. FH4518Y comp faulty
    By Jus Walker in forum Commercial
    Last Post: 19-07-2006, 10:34 PM
