Results 1 to 10 of 10
Thread: Relays on PCB's
    Nov 2006
    At home
    181
    Relays on PCB's
    hi guys, would i be correct in saying that the relays found on split/vrv a/c units are Solid state relays? i mean the ones that are solderd onto the boards and generally are "black blocks" looking like this http://www.drillspot.com/pimages/387/38734_300.jpg
    Oct 2001
    Nottingham UK
    5,668
    Re: Relays on PCB's
    No, solid state relays are totally electronic with no moving parts.
    Mechanical relays are different.
    Nov 2006
    At home
    181
    Re: Relays on PCB's
    so the relays found on PCB's (generally) are mechanical relays?
    Oct 2001
    Nottingham UK
    5,668
    Re: Relays on PCB's
    Generally - yes. A magnetic coil causing 2 or more contacts to make (energised) or break (not energised) - or vica versa depending on whether it's a NO or NC contact.
    A solid state relay uses an electrical 'signal' into the 'Gate' to cause the current to flow.
    http://en.wikipedia.org/wiki/Solid_state_relay
    Nov 2006
    At home
    181
    Re: Relays on PCB's
    thanks frank i just didn't know which was generally used, aint got any to hand so i couldn't check, thought i would ask, thanks again
    ps i live in Nottingham fancy taking me under your wing?, lol
    Split Croatia
    57
    6,151
    36
    Re: Relays on PCB's
    Solid state relays are generally used in domestic/commercial split air conditioning systems only for speed regulation purpose of AC fan motors. They regulate speed of fan by cutting power supply to fan motor many times per second (pulse width modulation -PWM). Main processor feed them with signal, and hall element in motor gives rotation speed achieved to main processor and it corrects its signal according to remote control settings and processor algorithm to achieve desired speed.
    Main reason for its use is because of many off-on cycles which cannot be achieved with normal electromechanical relay.
    For all other relay functions it is ordinary electromagnetic relay used.
    Jul 2007
    Australia
    1,845
    Re: Relays on PCB's
    It varies between brands. Panasonic used solid state in their splits for a while to power cond fans. They look similar to mechanical relay 'black boxes' but are really thin.
    Most have normal mechanical relays (including pana) for large current draw devices like compressors.
    I've seen a heap of solid state relays for heaters (lab incubators) though, not domestic.
    Mechanical relay is cheaper and more reliable than solid state, SS only used when noise, size or operating frequency is a problem
    Oct 2001
    Nottingham UK
    5,668
    Re: Relays on PCB's
    Quote Originally Posted by SkyWalker View Post
    Are you studying at Basford? assuming you are a student.
    Nov 2006
    At home
    181
    Re: Relays on PCB's
    thanks paul + nike, i was reading on the net about SSR and noticed they looked familiar but wasnt sure if "splits" used them as i thought i could hear the relays making a breaking, ei "moving parts".
    Frank - i will be next year, doing my level 3, did level 2 on night course (was forced to by my employer) doing lev 3 on day release! do you have any involvement at baseford?
    Oct 2001
    Nottingham UK
    5,668
    Re: Relays on PCB's
    Frank - do you have any involvement at baseford?
    I used to, but now I just support them with providing 'on the job' experience for the trainees.
  1. where to get soft starter relays?
    By paul_h in forum Electrical
    Last Post: 24-03-2008, 02:33 PM
  2. solid state relays
    By Temprite in forum Commercial
    Last Post: 11-02-2005, 10:17 PM
