Thread: r404 the same as r507?
17-10-2008, 11:25 AM #1
i hav a freezer that has lost its gas, the data plate shows that it takes 330g of r507 but it has a r404 compressor on it so will the charge be the same? 330g of r404a? Just need 2 know 2 price it up cos aint heard of it? Thanks
17-10-2008, 11:47 AM #2
Re: r404 the same as r507?
yep is the same..find first the leak,fix it and then charge it..
Regards Mihai
17-10-2008, 11:57 AM #3
nice 1, thanks for your help
17-10-2008, 02:08 PM #4
although the same we prefer the 507 than other.temperature glide,efficiency and many more advantage over 400 series of refrigerant with regards on low temp system.
regards,abet
17-10-2008, 02:23 PM #5
R507 and R404a have the same two basic refrigerants in them. R404a has a tiny bit of R134a in it for commercial reasons, (to make it different to R507 so another company can market it).
Either refrigerant will do the same job, R507 is preferred.
25-10-2008, 09:44 AM #6
The capacity of a plant with R404A will be about 3% higher than one working with R507A. ;-)
At least most of the european heat exchanger manufacturers refer to this factor in their catalogues.
25-10-2008, 07:42 PM #7
R507 instead R404a?
By Friobernal in forum RefrigerantsReplies: 49Last Post: 09-04-2011, 12:42 AM -
R507 in an R134a compressor: any danger?
By DaBit in forum Technical SpeculationsReplies: 30Last Post: 21-12-2009, 12:44 AM -
R507 in an R134a compressor: system design
By DaBit in forum Technical SpeculationsReplies: 17Last Post: 01-05-2003, 09:25 AM -
using R404 to chill watermixture
By fredperry in forum Technical DiscussionsReplies: 21Last Post: 21-05-2002, 10:44 PM -
Effect on design evaporator by using R507 instead of R22
By lappee in forum RefrigerantsReplies: 2Last Post: 18-09-2001, 05:15 PM
