Results 1 to 14 of 14
Thread: CDK Controls
21-02-2004, 07:59 PM #1
CDK Controls
Has anyone any info or a manual to program a CDK Miniscan.
What we need to do is rename inputs, alarm setpoints etc.
David
21-02-2004, 08:05 PM #2
CDK Controls
Hi David
Can you first verify its a miniscan.
regards mark
21-02-2004, 09:15 PM #3
Hi david
you could try cdk website, www.cdk.co.uk
They are pretty helpfull and are good with supplying information on their products. On our sites we only use mark 1 & 2 storescans.
21-02-2004, 10:37 PM #4
- Join Date
- Jan 2001
- Location
- Fife, Scotland.
- Age
- 66
- Posts
- 1,105
- Blog Entries
- 2
- Rep Power
- 20
and mark 3 Tony
22-02-2004, 02:16 AM #5
CDK Controls
Hi David ps
Cant say i have heard of a miniscan ,However the Storescan mk1,2,3 all have very easy to use configuration screens.
Renaming inputs will need to be configured by CDK any store legend changes graphic lay outs etc all done by lap-top.
The alarm settings are easily accesible via fitting program key in front door of panel,Press menu a number of sub- headings will appear ,scroll to configuaration,then system configuration,enter stub or case number by scrolling through LT1,2,3 etc until desired stub reached this then allows alarm threshold to be adjusted.
When you leave the screen by pressing menu until store map is shown in the left hand corner it should show data save active in red for a short while.
Any changes can be viewed by pressing menu and display events this will show any changes which have occured within the panel.
hope this helps if not ask again.
regards mark
22-02-2004, 08:16 AM #6
My mistake, its actually a Microscan.
David
22-02-2004, 11:00 AM #7
CDK Controls
Hi David
Im sure the config is the same as storescan if you want to check give Mark or Ian in technical a ring (01260)296300 im sure he will be happy to help.
Regards Mark
21-03-2004, 10:01 PM #8
Microscan is really easy to program.
There is a switch in the centre of the board on the inside of the door. Flick it to the opposite position and then follow the steps. Or as Mark said, ring (01260) 296300 and we can get a manual out to you.
Ian
24-03-2004, 07:54 PM #9
Re: CDK Controls
Is that Ian from CDK????
Dare i hazard a guess
24-03-2004, 10:33 PM #10
Re: CDK Controls
Originally Posted by MarkFiddy
How did you guess
Not looked in here for months, and then I find 2 vaguely relevant threads at the same time.
Ian
25-03-2004, 07:41 PM #11
Re: CDK Controls
Ian i missed the introduction
25-03-2004, 10:00 PM #12
Re: CDK Controls
Hardly
I didnt exactly jump up and down, shouting "Here I Am" I sort of sneaked in here, all quiet like
26-03-2004, 06:34 PM #13
Re: CDK Controls
Ok Ian thats fine
I will be e-mailing you for some technical info in the future
Im sure you love the supermarket forum in this site
Kind regards mark.
27-08-2004, 06:24 PM #14
Re: CDK Controls
Hi,Ian
What feed back have you had about the storescan 4 when used in conjunction with external alarm monitoring .
My opinion at the moment is mixed
Controls
By shogun7 in forum Technical DiscussionsReplies: 2Last Post: 28-01-2010, 01:26 AM -
Microm controls
By 750 Valve in forum CommercialReplies: 11Last Post: 15-03-2008, 09:07 AM -
Controls
By terrie73 in forum ElectricalReplies: 2Last Post: 01-04-2005, 08:54 AM -
Electronic Controls
By Bones in forum Supermarket RefrigerationReplies: 16Last Post: 04-04-2004, 06:52 AM -
Controls
By 750 Valve in forum Supermarket RefrigerationReplies: 27Last Post: 23-02-2004, 07:04 AM
