    Aug 2007
    U A E
    44
    carrier comp sameshild inner winding wire short
    hi frnds i m sid i want u'r openen i have face one problam i m working in oil refainry we have lotsoff carrier[ciarly] comprresor sameshild they inner insulationwire tuch short and show the magger valvo ground many compressor same problam, mechnisum is ok
    volts/amp everythig is normal lp/ hp/op stop the comp that time no discharged come to the winding side its sing the valv reed ok
    so plz help me
    thanx
    Sep 2008
    kent
    52
    8
    Re: carrier comp sameshild inner winding wire short
    what what what?
    11,025
    Quote Originally Posted by mwatts View Post
    what what what?
    Be patient and read these foreign, to you, posts with care an they will make some sort of sense.
    Remember that English is not the first language of a lot of the members here.
    495
    21
    Hello Faizsid do an acid test and check your running gear ie contactors not pitted and time delay between contators, and recycling times ie start stop and then check if you have enough horse power for the job.
  1. Replies: 12
    Last Post: 27-03-2011, 04:12 AM
