Results 1 to 13 of 13
16-02-2004, 12:51 PM #1
How come my freezer makes an ice maker like sound?
My chest freezer makes an ice maker like sound(click, crackle, crackle) somewhere from the cabinet or refrigerant lines shortly after the compressor kicks in.
This freezer have no moving parts except for compressor.
Where is this noise coming from?
16-02-2004, 01:40 PM #2
If you hear a sound +/- similar to the sound as you hear when there are small water droplets in baking oil (French Fries, one of Belgium's specialties), then overheat is not correct (too small) whereby small droplets of liquid '*****' enters in the hot sump (mostly the discharge pipe goes through the sump to heat the oil) and this droplet 'explode' due to the very high temperature difference.
Mostly associated with an completely frosted up evaporator.
Look inside if evaporator is clean and free of ice. Otherwise, I don't have an idea.
PS : Talking about FrenchFries: Ever heard of a French Fries shop? There is no correct english translation for it I think. Some sort of fast food.
We have thousands (+/- 8.000) of them in Belgium. There are even books published of this.
And a driving van who sells ice cream from house to house?
We made last week an offer for 3 of this for Dubai.
It seems not existing there and there must be a market for this, especially over there when it's always hot.
Som pictures of older Frietkots.
http://www.ping.be/pinball/belgofun.htmlLast edited by Peter_1; 16-02-2004 at 01:51 PM.
16-02-2004, 04:18 PM #3
forget all that french fries nosnsense
try -
http://www.harryramsdens.co.uk/about/history.html
ice cream?
http://www.donovans-icecreamvans.co.uk/index.htm
cheers
richard
16-02-2004, 05:00 PM #4
hey dude,
I can only add that some times, one of the springs that hold the motor brakes or move out of place so the motor is knocking on the shell.
also, check that copper pipes are not touching each other.
richard. where the newspaper gone?
without it, fish and chips will never be the same.
chemi
16-02-2004, 08:02 PM #5
Hi peter
Here in England they are called Fish & Chip shops. Can't seem to find them much elsewhere in the world although I have savoured the mobile version in both Germany and Holland. On my trip to Australia at Xmas we found lots of English style Fish & Chips shops and took advantage on many occasions. Really fattening and great with a cold beer. Can't really seem to get the mushy peas though - must be an English thing
Frank
16-02-2004, 08:14 PM #6
hi frank
have to agree with you,
there is nothing like hot, greasy, and fresh fish and chips.
from some reason, when not in the UK, it never tastes as good.
chemi
16-02-2004, 08:34 PM #7
chemi
do you ask for the batter bits on your chips?
Frank
16-02-2004, 08:48 PM #8
yes sir!
I do
cemi
21-02-2004, 06:08 AM #9
MMMM, Chips with chicken salt and vinegar. The shops are called Milk Bars over here, its a throw back to the old days, but we'd have thousands of them, staple diets of the middle class, fish, chips and hamburgers (REAL burgers, not like McAvg.)
21-02-2004, 10:47 PM #10
It's not metal to metal banging sound from compressor motor colliding with the shell...
It's more like click click click sound from a ball valve on a water heater.
06-03-2006, 10:33 AM #11
Re: How come my freezer makes an ice maker like sound?
i need software to design ice cream freezer or the optimum method to design it
06-03-2006, 11:52 AM #12
06-03-2006, 08:47 PM #13
Are you sure there isn't someone trapped inside the freezer?
It's probably either the skin condenser expanding inside the blown foam or the ice on the inside walls cracking due to the difference in temp. between the evap & the ice itself. How thick is the ice on the inside?Last edited by phil68; 06-03-2006 at 08:55 PM.
Noah had to leave the dinosaurs behind as they would've sunk the boat.
Amana refrigerator/ice maker problem
By SCStewart in forum Trouble ShootingReplies: 6Last Post: 08-08-2010, 10:50 PM -
walk in freezer refrigeration sizing?
By trammd in forum Technical DiscussionsReplies: 10Last Post: 02-11-2006, 11:56 AM -
Freezer operation in my garage
By sonjand in forum FundamentalsReplies: 5Last Post: 02-08-2006, 10:25 PM -
please help with Kenmore Upright Freezer
By lrn376 in forum Trouble ShootingReplies: 0Last Post: 09-07-2006, 10:40 PM -
Ice cream freezed with sound
By Peter_1 in forum New TechnologiesReplies: 3Last Post: 11-05-2006, 02:44 AM
