Thread: Freezer to coolroom conversion
20-09-2008, 07:21 AM #1
hi all,
what are the issues with converting a walk-in freezer to a coolroom. the system will be oversized, no defrost required, fan on always. i am a bit concerned about the prospect of short cycling. any one with experience on this? I know its not an ideal situation but what do you do when you need a fridge not a freezer?
cheers
20-09-2008, 10:58 AM #2
Re: Freezer to coolroom conversion
from my experience, you are facing many problems, capacity will be too high, compressor will not get enough cooling.
If you change the orifice in the TEV and the compressor, seal the HGD line after the TEV, you can get descent results.
20-09-2008, 11:35 AM #3
thanks for the help chemi-cool!
ice cream truck freezer
By GaryC in forum TransportReplies: 7Last Post: 06-12-2008, 02:19 AM -
Hotpoint FFA71 Freezer High Temp Light / Fridge is Freezing
By sumnerpa in forum Trouble ShootingReplies: 1Last Post: 19-08-2008, 03:16 PM -
Freezer compressor running 20 Hours/day
By rickcw in forum DomesticReplies: 12Last Post: 08-03-2008, 11:50 PM -
Need help quick with walk-in freezer issues!
By hysiderafter in forum CommercialReplies: 5Last Post: 12-12-2007, 12:57 AM -
Trolley freezer & blast freezer
By smpsmp45 in forum NH3Replies: 0Last Post: 25-08-2007, 07:29 AM
