Thread: Drain Hose Valve?
18-09-2008, 03:54 PM #1
Drain Hose Valve?
I am supporting a wall mount air conditioner in Japan and an HVAC tech there suggested we add something he called an "Air Cut Bulb" to the end of the condensation removal drain line which lets water drain out but then closes to prevent humid air from being sucked back into the system.
Does anyone know what this device might be called in the U.S.? I can't find anything that seems to be what they are suggesting.
Thanks!
Keith
18-09-2008, 04:16 PM #2
Re: Drain Hose Valve?
Do they mean a Hepv0?
http://content.wavin.com/__802571EF003CF447.nsf/0/990E1309736901188025729F003BF54E/$FILE/HepvO_Product_Guide.pdf
18-09-2008, 08:13 PM #3
May be you have seen a water U trap?
19-09-2008, 08:12 AM #4
i'm guessing that as it was described as a valve, and had the facility to close after it was a Hepv0 (to those in the UK a fanny trap, just the not the US version of fanny)
19-09-2008, 03:32 PM #5
In transport HVACR, we use what our US colleagues call " kazoo traps " - those are the pinched hose end -fittings we install on bottom of evap drain hoses, outside the reefer box or bus as case may be.
Of course we are using a soft, pliable drain hose.
hope it's of some help to you.
T-PRemember what Augustus once said:
"festina lente" - make haste, slowly!
19-09-2008, 08:53 PM #6
I think daddy cool is referring to this http://www.plumbworld.co.uk/hepv0-se...waste-305-1788
19-09-2008, 08:57 PM #7
Come across those Frank on an Ambirad heater system.
The fan suction was such that those device were being sucked inside out and sounded most painful.Brian - Newton Abbot, Devon, UK
Oversize Relief Valve
By Dacosta in forum NH3Replies: 1Last Post: 05-09-2008, 11:35 AM -
Service Procedures For TK Scroll
By absolute-zero in forum TransportReplies: 0Last Post: 03-02-2008, 07:42 PM -
Compressor valve test
By RackMechanic in forum Air ConditioningReplies: 11Last Post: 03-02-2008, 05:57 PM -
Benji
By benji in forum Trouble ShootingReplies: 29Last Post: 30-01-2008, 01:25 PM -
TEV with MOP: how to keep valve body temp above bulb temp?
By DaBit in forum FundamentalsReplies: 5Last Post: 16-10-2002, 12:38 AM
