Thread: Mitsubishi FDTN508C
06-09-2008, 01:41 AM #1
Mitsubishi FDTN508C
Hello,
Came across the above cassette unit today and the automatic swinging louvres are not working, i couldn't get good access to the underneath of the unit as the client had a magazine rack underneath it but i will be going back shortly once the rack is moved.
Does anyone know how hard it is to access the motors for the louvres? and who do i contact about getting new ones? mitsubishi?
anyone had experience with these indoor units?
Cheers,
airlfo
06-09-2008, 09:42 AM #2
Re: Mitsubishi FDTN508C
lover motors are normally at the corner of the cassette fascia,the one with mitz displayed on it,drop filter panel and access to corners is clear,just remove screw and corner slides out
07-09-2008, 12:45 AM #3
cool where would i order these motors from?
07-09-2008, 04:49 PM #4
mitz should stock them mate
10-09-2008, 10:48 PM #5
You would get them from the local mhi distributor / agent
Brit Cit
Mitsubishi vrv
By dakesojo in forum Air ConditioningReplies: 20Last Post: 22-09-2009, 01:04 PM -
Mitsubishi inverter problem
By R1976 in forum Air ConditioningReplies: 3Last Post: 16-06-2008, 09:54 PM -
Mitsubishi Light Truck Refrigeration
By Mastercool in forum TransportReplies: 2Last Post: 23-11-2007, 06:15 AM -
mitsubishi city multi fault code
By robin r33 gtr in forum Air ConditioningReplies: 5Last Post: 05-11-2007, 10:23 PM -
Mitsubishi compressor lock
By marc5180 in forum Air ConditioningReplies: 29Last Post: 08-10-2007, 05:48 PM
