Thread: Kelvinator wiring diagram
26-08-2008, 01:18 PM #1
Hello,
I'm after a wiring diagram for a Kelvinator cyclic 380. Does anyone have one or know a site where I can easily get one?
Thankyou
26-08-2008, 05:18 PM #2
Re: Kelvinator wiring diagram
If it's a cyclic it's not going to have much of a wiring diagram.
mains->thermostat->compressor->neutral
mains->doorswitch->light->neutral
28-08-2008, 12:40 PM #3
Thankyou Paul,
The mains goes into the compressor body and there are 4 wires leading to the rest of the fridge. How do I determine which ones are for the thermostat?
Mal
28-08-2008, 01:11 PM #4
Are they all different colours?
Have you taken the thermostat housing apart to see what colours goes to the thermostat?
Why do you need to know which ones are the t/stat?
I'm just asking because if there's no problem with the t/stat, but you are needing to know for other reasons:
with the door closed and the power off and the t/stat set to max cool, the two wires for the t/stat would be showing 0 ohms with a multimeter because there would be a closed circuit through the t/stat, and then go open circuit when you move the t/stat to the off position.
Disconnect all four first before testing, to make sure you haven't just grabbed two neutrals. Remember where they were connected though.Last edited by paul_h; 28-08-2008 at 03:50 PM.
Single stage refrigeration system optimizing diagram
By autt in forum System OptimizationReplies: 34Last Post: 03-12-2008, 03:13 PM -
30 GB wiring diagram
By Jai in forum Air ConditioningReplies: 4Last Post: 17-07-2008, 11:54 AM -
Electrical Wiring Diagram
By bhasadu in forum ElectricalReplies: 0Last Post: 21-06-2008, 09:15 AM -
Piping diagram for VRV system
By wilks in forum Air ConditioningReplies: 6Last Post: 10-07-2007, 06:55 PM -
costan wiring diagram
By al in forum ElectricalReplies: 3Last Post: 04-01-2007, 05:14 PM
