    Sep 2003
    ISRAEL
    72
    4,248
    Unhappy Need a new vacuum pump
    After 28 years of excellent service, my Gould vacuum pump have started to leak from the mechanical seal.
    Nobody at Goulds pumps in the US of A can help, so, I'm looking for a new one.
    I was offered the Spanish Telstar.
    Doe's any one have any experience with it?
    Feb 2007
    2,473
    45
    Re: Need a new vacuum pump
    Wouldn't it be easier to just replace the seal?
    I'm sure it will be a standard one, available from any good mechanical wholesaler.
    As it's only 28 years old, it must be worth repairing it...
    Sep 2003
    ISRAEL
    72
    4,248
    Good thought..................
    One little problem though,
    How am I going to vacuum when my pump is in pieces???????????
    Apr 2006
    stafford
    42
    974
    if you after a new one its the javac shark vac pump everytime for me
    Shark Vacuum Pump Douple stage high vacuum pump, unique robust construction.
    · Dual port 1/4", 3/8" SAE Flare.
    · Inlet isolation valve.
    · Built in oil pump with anti-suck back.
    · Quiet running, cool to touch.
    · Recognised pump down curve for maximum pump down time.
    · High preformance gas ballast.
    Capacity 5.2 cfm Vacuum <15 micron Part Number VNR-152-2.
    Paul
    "KEEP IT COOL"
    May 2008
    66
    802
    Quote Originally Posted by The Viking View Post
    same feeling here Viking, mine is about the same age,but have a small junk pump (125€)aside when my baby needs being repaired.
    always glad to have her back.
    Ice
    May 2008
    66
    802
    Why,
    its all in the sound you now, recognize when she's done whit her job. never wrong.
    Ice
    Sep 2003
    ISRAEL
    72
    4,248
    This is going to be the new pump, will give me time to carefully repair the old one.
    http://www.telstar-vacuum.com/en/pro...cuum+pumps.htm
  1. Vacuum cleaner as a vacuum pump
    By chemi-cool in forum Chit Chat & Service Stories
    Last Post: 14-08-2009, 10:11 PM
  2. Vacuum Pump CFM
    By w.l.ong in forum Technical Speculations
    Last Post: 27-10-2008, 02:20 PM
  3. Troubleshooting a vacuum pump and gauge set.
    By Old Codger in forum Fundamentals
    Last Post: 08-08-2008, 05:13 PM
  4. Vacuum Pump in a Hazardous Area?
    By Cold Down Under in forum Hydrocarbons
    Last Post: 08-06-2008, 12:20 PM
  5. inverters pulling vacuum
    By bangoman in forum Air Conditioning
    Last Post: 05-02-2008, 09:12 PM
