Thread: Air Flows
26-07-2008, 08:47 AM #1
Air Flows
What is the leagal requirements and industry standards for air supplied into domestic, comercial and industrial applications. How does one calculate the amount of fresh air required?
26-07-2008, 01:56 PM #2
Re: Air Flows
Your'e asking for a lot of information, there is no simple answer and depends on where you are!
Some info is found here but not free.
https://eweb.ashrae.org/eweb//Dynami...c-f16d8e07e4a0
https://eweb.ashrae.org/eweb//Dynami...9-1add2b47df2e
https://eweb.ashrae.org/eweb//Dynami...0-a4ec114a0f22
26-07-2008, 02:24 PM #3
Re: Air Flows
There is no legal requirments for ventillation to be provide in any area less than 80 Msq anything more than that is worked out based on what the area is like a troilet needs 8 - 10 air changes an hour where an office area needs 3 to 4 and so on. to calculate this you need to work out you can either base it on meters cube or liters per second.BISRA have a guide on this as well which may be of use.
hot gas defrost - top feed/bottom feed
By SimonBrown in forum NH3Replies: 27Last Post: 10-07-2007, 03:39 PM -
NH3 hot gas defrosting
By SimonBrown in forum IndustrialReplies: 11Last Post: 08-10-2006, 12:57 PM -
Minimal required R134a speed in suction line
By DaBit in forum CPU OverclockersReplies: 32Last Post: 08-05-2002, 05:19 AM
