Thread: huskey ceiling cassette
23-07-2008, 08:01 AM #1
The condensate lift pump on a huskey ceiling unit has gone down but the builders have fitted a plasterboard ceiling flush with the unit with no access does anyone know if you can access the pump from inside the cassette or will the ceiling need to damaged to get at it from the side
thanks
23-07-2008, 11:38 PM #2
Re: huskey ceiling cassette
Husky Group Ltd,
The 4 Degree Centre,
Bilton Way,
Lutterworth, LE17 4JA
Tel: 08700 62 20 10
Fax: 07000-48759328
BEST PEOPLE TO SPEAK TOO,AS THEY WOULD TELL YOU FOR SUREPaul
"KEEP IT COOL"
23-07-2008, 11:52 PM #3
23-07-2008, 11:59 PM #4
if its just a 4 way cassette and the internal pump has gone then dropping the grill,drip pan and fan blade i would of thought would give you access,(it will on every make ive worked on)if it the tank pump then reach for your pad saw as that celling is coming down and cut your self a access hatch as that will be needed for servicingPaul
"KEEP IT COOL"
24-07-2008, 12:57 AM #5
... or install a new pump if you can hide it somewhere, plastic tubes are easy to hide if you use the same color.
27-07-2008, 10:53 PM #6
Cheers hadn't thought of putting a new pump in line as i think theres room, at present the lift pump is gravity fed into a tank pump in a cupboard below.
Thanks for the suggestion
27-07-2008, 10:56 PM #7
Cheers Paul I'll look at that option when I return, but my 1st thought was evap was in way ?
Ceiling cassette enclosures / casings
By old time fridgy in forum Air ConditioningReplies: 12Last Post: 30-03-2011, 12:10 PM -
Toshiba RAV Ceiling Cassette
By Grizzly in forum Air ConditioningReplies: 5Last Post: 09-03-2008, 07:00 PM -
old cassette
By chillymatt in forum Trouble ShootingReplies: 7Last Post: 24-02-2008, 11:28 PM -
ceiling cassette fan
By aza in forum Air ConditioningReplies: 5Last Post: 12-12-2007, 10:48 PM -
Air conditioning ceiling cassettes
By iceman007 in forum Air ConditioningReplies: 21Last Post: 14-02-2004, 12:59 PM
