Results 1 to 15 of 15
22-07-2008, 09:08 AM #1
size of brine tank for 10ton block ice plant
hi, member
i have been in commercial refrigeration for quite sometime and my company going in the industrial side of refrigeration.can somebody give me some reference guide on the design of ,block ice plant,heringbone,agitator,size of brine tank nd others.please help
22-07-2008, 11:12 PM #2
Re: size of brine tank for 10ton block ice plant
I have most of that data in some old manuals I will make a few copies and send some info on to you
bruce
22-07-2008, 11:19 PM #3
Whose old manual is it? One of Yorks?
23-07-2008, 02:15 PM #4
bruceboldy,
Much appreciated sir,will wait for that valuable manual.
many thanks
09-09-2008, 08:16 PM #5
Hi Bruce,
Can I get a copy of that info also? My uncle owns an old block ice plant in Vietnam is looking to me for help in expansion of the plant.
Thanks,
27-10-2008, 03:48 PM #6
Re: size of brine tank for 10 ton block ice plant
DEAR AS PER ME YOU SHOULD CONTECT Mr. VIR KUMAR JAIN HE HAS DEVELOP AN ICE PLANT ON R-22 WITH LESS POWER CONSUMPTION & HIGHER RETURN , I HAVE ALSO A ICE PLANT OF 210 BLOCK/DAY ON R-22 GAS WITH LOAD OF ONLY 35AM,
HIS CONTECT DETAIL ARE;-
M/s MILAP ENGINEERING Co.
Mr. V.K JAIN
K 38/3 GOL GHAR
VARANASI, (U.P)
INDIA
221001
Ph:- 91-(0)542-2332634
Mob.- 91-9415222749.
i have been in commercial refrigeration for quite sometime and my company going in the industrial side of refrigeration.can somebody give me some reference guide on the design of ,block ice plant,heringbone,agitator,size of brine tank nd others.please help[/quote]
28-10-2008, 01:24 AM #7
Hi guys,
block ice plant design requires good understandings of the process.
you need to layout the ice can & how the overhead cranes should works to hoist.
the I-beam supports & its cantilever positions determines most of your tank dimensions.
you also need to decide your ice block's weight for the height of the tank.
Also, how you want the tank to be build.
good luck!!!!Hendry
"What uncertainty means to you, and you only?"
21-11-2009, 11:09 AM #8
size of brine tank is 5Mx19M. Brine Tank will hold Ice Cans(300 Lb/135 Kg)189 nos,Vertical Agitator 16" dia-4 Ft long & Cooling Raceway Coil
21-11-2009, 04:18 PM #9
- Sep 2009
- Iran
- 66
- 672
- 1
- 19
We have different type of cans 15 kg. 25 Kg. 50 Kg. and each one of that has 2 or 3 size
For example 25 Kg.
10 Ton/24h
1000/2 =5000 kg/12h
5000/25kg. =200 cans
Each can = 22mm X 22mm X 1250mm
12 cans in one line So 12 X 18 = 216 cans
And….
mail to me I will send you copy of calculation .
Gholbehan@yahoo.com
21-11-2009, 04:20 PM #10
- Sep 2009
- Iran
- 66
- 672
- 1
- 19
Dear harani
I think your size is not right could you mail it to me to check it please
21-11-2009, 07:57 PM #11
Slightly of subject, what do you use a 10Tonne block of ice for? Is just for transport, then broken into smaller amounts else where?
07-02-2010, 08:42 PM #12
Company for 10ton block ice plant
I have personally bought a 10ton/24 hour Block ice plant from Zahra Company that manufactures block ice plants and is based in Lebanon. The quality is as high as the ones I observe in the U.S as there quality is 100% satisfactory and the ice machine parts are all imports from germany and USA.
As for the size it was a 25kg block ice and awesome American design for a great value price .
zahraice.com/home.html
Hope this helps , they also have catalogs of the design on there website .
26-10-2010, 03:12 AM #13
14-11-2010, 02:13 PM #14
[if any is having the reference dat for designing the Ice stoorage plant please provide to me
I have to design one small plant for myself.
quote=boy;114020]hi, member
05-01-2011, 12:12 AM #15
hi can some one email me drawings of a complete ice plant and sizing of all the units.
How do i size a thermal Storgae Vessel(Buffer Tank)
By Tamarco in forum Technical SpeculationsReplies: 8Last Post: 09-08-2010, 09:53 PM -
size of brine tank
By boy in forum Air ConditioningReplies: 6Last Post: 29-07-2008, 03:03 PM -
Cop Of Brine Plant And Chilled Water Plant
By patilvasudeo in forum FundamentalsReplies: 2Last Post: 16-07-2008, 06:43 AM -
Used Ice Block Plant
By apilorge in forum IndustrialReplies: 1Last Post: 10-04-2008, 12:19 AM -
size of glycol tank
By guapo in forum IndustrialReplies: 2Last Post: 16-03-2006, 04:57 PM
